show isis counters
show isis counters {area [area_name | all] | vlan [vlan_name | all]}
Description
This command displays counters for an area or a VLAN.
Syntax Description
area_name Specifies a router process for which to display the IS-IS counters. If you do not specify an IS-IS area, the software displays counters for all areas.
vlan_name Specifies a VLAN for which to display IS-IS counters.
all Displays IS-IS counters for all areas or VLANs.
Default
None.
Usage Guidelines
If you enter the show isis counters command without any additional keywords or parameters, the software displays the counters for all areas.
The following command displays the IS-IS counters for the configured area:
show isis counters
The following command displays the IS-IS counters for the SJvlan VLAN:
show isis counters vlan SJvlan
Platform Availability
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
